Soft Phones with Base numbers
We have a number of users who will be working externally and from home using corporate laptops. Is there a way of adding base numbers to soft phone software and pre-installing this on laptops. The base phone number on the soft phone never changes.
If a user picks up a laptop and takes it home to work -
Is he/she able to log in using her own extension number?
Is there any more in licence fees?
Is there a easier way of adding this into CM such as a script to complete all 3000 base numbers and laptops in one go.
We are currently using Call Manager 6.1
Jay
1 REPLY
You can configure CIPCs for that.
They will consume DLUs.
You can either configure a fixed number or configure EM.
Use BAT for the CUCM config of the CIPCs.
java
If this helps, please rate
www.cisco.com/go/pdihelpdeskY
java
if this helps, please rate
145
