Community Member
Softkey Template 8941
Experts,
I have a very funny question, i don't like to post but i have to becz of my lazy manager
My manager wants missed and received calls menu beside new call and redial on the screen(first) which is always available, he is saying me i dont want to go by the long procedure <settings>directory>scroll down>received call etc,,etc, Is it can be configurable.????
By the way the undefined softkey is used for what ???
No, you only get to configure the softkey options you see, there's no option for directories under any softkey, nor can they be customized.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
Dear Jaime,
what are the undefined softkey is used for ???
To create a relative place holder for a softkey, add the Undefined  softkey. This allows the softkey that you added to occupy the same  softkey position in all call states.
Yosh
HTH Regards, Yosh
Community Member
Dear
I read the above line in the guide but i didnt understood, can you write any example
The "undefined softkey" is just a way to leave a gap between other softkeys. Exmaple:
Without the "undefined softkey"
Redial Newcall CfwdALL
With the "underfined softkey"
Redial "BLANK SPACE" Newcall CfwdALL
Yosh
HTH Regards, Yosh
Community Member
ok i see,
the above line means in "connected" call states and in "off hook" call states i will get a space in between
correct me??
Yes as long as you put the "undefined softkey" in the same position.
Yosh
HTH Regards, Yosh
Community Member
Dear,
By providing a space in between what cisco wants to proof. what is the use of that, that doesnt make any sense.
As the name defines it is undefined that means cisco should provide some way to customize the undefined key.
Please suggest
Adam,
The "undefined softkey" is really for environments where users get easily confused by softkeys that can be used in mutliple states, being in different locations. The softkey could also be used as an empty space, for a future softkey to replace.
Yosh
HTH Regards, Yosh
VIP Super Bronze
If the request is to reduce the number of button presses, I can offer two options:
  • Use a 8961/9900 series phone where the missed calls directory appears on the session buttons (right-hand side of the display) as a button. This has the advantage of actually showing whether there are missed calls.
  • Replicate the Missed Call directory URL as a generic service URL, modify the Phone Button Template to add a Service URL-type butotn, and subscribe the service to that button.
Please remember to rate helpful responses and identify helpful or correct answers.
208
