SOFTKEY-TEMPLATE
I am installing the CCM 5.1, in the IP PHONES (7911G) is show the buttons: Redial, Newcall, MSG!
My solution don't have voicemail, I want exclud the button softkey MSG. How can I do it?
Re: SOFTKEY-TEMPLATE
You can do that from Device->Device Settings->Softkey template
If you have already created a template, edit it.If you have not, you have to create a new one by copying the Standard user and chaning the layout.
You would have to change layout for "on-hook" call state.
Following is the cisco doc
http://www.cisco.or.at/en/US/docs/voice_ip_comm/cucm/admin/5_1_3/ccmcfg/b06skey.html#wp1023689
I create a new softkey-template based in standard user.
In "on hook" there are 3 items (Redial, Newcall and ForwardAll.
In telephony show-me 4 items (Redial, Newcall, MSG and ForwardAll)
I want that don't show me MSG option. Just the 3 items (Redial, Newcall and Forward All equal the softkey-template created for me!
PUTZ!!!
Thanks!
243
