Softkey update - phones will not update?!
I have tried altering several phones to use a new softkey template, though the phones will not update to this sofkey template, despite applying+restarting, and also physically rebooting the phones!
Has anyone seen this?  I am not aware of any dependancies in doing this?
Steve
Hi, Can you provide below information ?
- Version of CCM?, any patch? - Was this working before?, if yes what changed? - Is this a new installation? - Does it shows any error? - What is the behavior that you are seeing?
- What softkey you are trying to use ?
- Have you checked if the replication is fine between PUB and SUB (on which phone is registered) ?
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Re: Softkey update - phones will not update?!
System version: 9.1.2.10000-28
No changes
No
Where would I look for this please?
Phones remain using existing Softkey template and will not change, though newly imported/registered phones do get assigned the new profile. I am managing CUCM's from the Publisher.  Replication issue??
A newly created one
Where should I check this please?
- note I have logged on to the subscriber which the phone is registered to and can see the softkey setting is as the publisher.
Steve
Exactly what phone model is this???
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
343
