Softphone with ThinClient Win2003 WTS
I am facing the following situation: I have a router 2801 with CCME and some 7911 installed and running, but need to install softphones on the stations, but stations are ThinClint via WTS Win2003. Could anyone help me?
Thank you very much.
Re: Softphone with ThinClient Win2003 WTS
I would recommend that you use the netpro forums.  This community is for cisco small business.
http://www.cisco.com/go/netpro
But, to answer your question, I am not sure if it is possible.  The softphone use the MAC Address of the computer it is connected on (which won't work) or you can enter a different device name, which might work for you.  The problem I see is having too many instances of this running.  I am also not sure that you can get the audio back to the thin clients, but I am not an expert with thin clients.
Thank you for reply, I will use the NetPro forums
542
