Software Compatibility Matrix between Unity Connection and CUCM
I wan to upgrade my CUCM from  8.6.1.20000-1 to 8.6.2.20000-2.
My question is Could be able to just upgrade the CUCM and not the UNITY Connection?
Im planning to the Unity upgrade later.
any recommendation will be great
thanks
3 ACCEPTED SOLUTIONS
Yes, you can. I presume your CUC is also 8.6.
GP.
Pls rate helpful posts by clicking on the stars below the post !!
Depends, if you're talking about a CUCMBE 5K the answer is no, you upgrade the whole system.
If they're standalone installs, then yes.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
CUCM 8.6.2 is compatible with CUEAC/CUBAC 8.6.2.11. Refer page 12 of following release notes
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmac/arc/CUBDAC_Rel_Note8_6_2_11.pdf
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmac/arc/CUEAC_Rel_Note8_6_2_11.pdf
GP.
Pls rate helpful posts !!
GP.
my unity Connection is
Version 8.6.1.20000-109
Could you provide the documentation that show the CUCM could be a higher version than the unity COnnection in my case
Sure, here all you need to ensure is the compatibility between CUCM & CUC version. Which is documented clearly here http://www.cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html#wp38791
CUCM & CUC compatibility is very simple.
GP.
Pls rate all helpful posts !!
thanks
The reason im doing this is because  Im
Installing Call   Manager version 8.6.2.20000-2 (to fix the CDR Database issue) but it  breaks CUEAC   "System Version: 8.6.1.9" (Administration Version: 8.6.1.158)
what would be the version for the CUEAC and for the CUBAC client that works with the cucm
8.6.2.20000-2. that im looking to upgrade?
thanks once again!
GP.
java
java
I got 1 CUCM and 1 Unity connection ( no clusters )
where can I see if the im running
CUCMBE 5K ?
Hall of Fame Super Red
Hi Alberto,
Supported Version Combinations for Cisco Unity Connection and Cisco Unified Communications Manager
Cisco Unity Connection 2.x and Later
Any version of Cisco Unity Connection 2.x or later is supported for use with any version of Cisco Unified CM 4.1(3) or later.
Cheers!
Rob
Re: Software Compatibility Matrix between Unity Connection and C
4353
