11-04-2010 06:15 AM - edited 03-16-2019 01:44 AM
Is the website being redesign because I can't any VOIP/Call Manager(UCM) downloads?
11-04-2010 06:20 AM
Hey Joe,
Yep,something is wrong there right now I only have access to items
already in my download cart. Ugh!
Cheers!
Rob
11-04-2010 06:21 AM
Have you tried contacting web-help@cisco.com ?
11-04-2010 07:32 AM
Hey Joe,
It's back up now
Cheers!
Rob
11-04-2010 08:36 AM
Thanks Rob
11-04-2010 09:00 AM
Rob,
I'm running UCM 7.12 and would like to upgrade to UCM 7.1.5. Where exactly are two upgrade files located now. I think I've opened up every URL. I assumed that I was looking for two large downloads that I copy together to create the one iso image.
Joe
11-04-2010 09:24 AM
Hi Joe,
Unified Communications Manager / Cisco Unity Connection Updates
Note: The installation file described in this readme only applies for installing this Service Update on Cisco Unified Communications Manager Release 6.1(3x), 6.1(4x), 6.1(5x), 7.0(2x), 7.1(2x), 7.1(3x), 7.1(5), 7.1(5a), 7.1(5b), 7.1(5)su1, 7.1(5)su1a or any 7.1(5)es from 7.1.5.11001-6 to 7.1.5.21011-2. Upgrades from 513x versions use an alternate readme that is linked to those upgrade files. Upgrades from 6x need to be requested via PUT (www.cisco.com/upgrade) to obtain the necessary license.
The first (top) 2 files when you click on 7.1(5b)su2
UCSInstall_UCOS_7.1.5.31900-3.sgn.iso_part1of2
Release Date: 10/AUG/2010
Size: 1741984.00 KB (1783791616 bytes)
UCSInstall_UCOS_7.1.5.31900-3.sgn.iso_part2of2
From the ReadMe;
Release 7.1(5) is available in both restricted (which is the release type that has always been available from Cisco) and unrestricted versions of software to comply with import / export restrictions to various countries. The unrestricted version is available in limited markets. Please refer to the 7.1(5b) Release Notes referenced above for a more detailed description.
The file names and MD5 values you will use for this upgrade are:
•UCSInstall_UCOS_7.1.5.31900-3.sgn.iso_part1of2
•UCSInstall_UCOS_7.1.5.31900-3.sgn.iso_part2of2
The MD5 for the Restricted combined download is: 186342d16cb4b40ef42606ead5a1fdb6
http://www.cisco.com/web/software/282074295/36574/cucm-readme-715bsu2-2.pdf
Cheers!
Rob
11-04-2010 02:12 PM
Hey Rob, I have a Cisco 2811 running IOS c2800nm-spservicesk9-mz.150-1.XA4
I am trying build it up for cme/cue but am getting confused by all toe different docs. I am not sure what fils are really needed and if there is an order to install them in. Can you help me at all? I have not been able to attend training and have bee trying to figure this out on my own. Any help is appreciated!
Cheers,
Jim
11-05-2010 05:32 AM
Hey Jim,
Can you have a look at this pretty nice video tutorial, it has some good info
for getting you started (3 part video series
http://www.youtube.com/watch?v=V7yEHz2tj64
Cheers!
Rob
11-05-2010 07:38 AM
Thanks Rob! I hope this helps. I get frustrated with not being able to get proper training and having to support this. I will have to look from home as we are blocked from youtube at the office. I do have another question:
I am running IOS c2800nm-spservicesk9-mz.150-1.XA4.bin and trying to configure the cnf-file location on our lab router and keep getting this:
Router(config-telephony)#cnf-file location flash:
Warning: The flash file syem does not support
directories, all files will be stored in the root
directory. Make sure to switch to another storage
device if there are a large number of phones
%Error: The flash file system does not support
Why?
I am having a hard time finding the right CUCME package to dowload. Again, I am on c2800nm-spservicesk9-mz.150-1.XA4.bin for the IOS. I was trying to install/xtract cme-full-8.0.0.1.tar, but it is taking a very long time and then bails out. Thoughts?
