Silver
Software MTP
Hi Pros,
Can I perform the following two configurations in the same gateway?
voice card 0
dspfarm
dsp services dspfarm
AND
dspfarm profile 10 MTP
codec g729r8
codec pass-through
maximum sessions software 100
associate application SCCP
I read in one of Cisco's documentations that if "dsp serivce dspfarm" is configured in a gateway the only available MTP option would be the hardware MTP. If we want to use the software MTP we need to remove the dsp services dspfarm" command from the configuration. Is this a valid statement?
Thanks for shading some lights on this one,
MK
Hall of Fame Super Silver
Software MTP
Not sure where you read it, but to my knowledge this is incorrect. I have configured it on many occasions without any problems, and cannot think of why DSP sharing for profiles would have any affect on software MTP.
HTH,
Chris
Software MTP
No, you can have both.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Silver
Re: Software MTP
For some reasons I am not able to cut and paste the link into this page.  I am attaching the address as a txt file.
MK
Re: Software MTP
Interesting, I was not aware of this, and this doc looks very old.  You might want to open a TAC case to validate this.
Chris
Silver
Re: Software MTP
I am sure there're some TAC poeple in this forum. Anybody can confirm the below statement before I open a TAC case?
"Software MTPs are supported on the router only if the dsp service dspfarm command is not enabled on the voice card."
MK
Re: Software MTP
Well, as Chris said, that document is pretty old. Pretty sure that SRND will say something about it:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/media.html#wp1046314
If you look at some recent docs:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080b4f916.shtml
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080334294.shtml
There is no mention of that weird limitation
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Silver
Re: Software MTP
Can someone please let me know why I am not able to cut and paste into this window.
The attached address is pretty recent.
Silver
Re: Software MTP
Do I have to consier the above statement is valid?
MK
335
