Software to try CTI Ports ?
I have some problems integrating a third party unified messaging solution with a Cisco CallManager 4.1.3.
This UM Solution is using CTI ports to connect to CCM. CTI Ports are well registered but I'm unable to establish incoming and outgoing calls.
I verified everythings (partition, CSS, user association, ...) but without success.
So I'm searching to test CTI Ports without the 3rd Party UM Solution.
Something like a CTI Phone that would be able to register CTI Ports on CCM and to make/receive calls.
Does it exist ? If yes, were can I find it ?
Thanx,
Bastien.
Green
Re: Software to try CTI Ports ?
Use Cisco IP Softphone and setup a CTI port.
Softphone will control the CTI port.
http://www.cisco.com/cgi-bin/tablebuild.pl/ip-softphone
Thank you for your answer !
It's a shame I did not think about that !!
:p
hello,
I'm trying to use the CTI ports to receive and make calls, but with no success. (using Jtapi to monitor those calls).
So, to test those cti ports, I'm using a cisco softphone, but I cannot able to detect any lines (I configured already a cti port in CallManager and saw the troubleshooting in the cisco's documents).
Could you help me?
I'm working with CallManager 4.2
This is my email: pedro.albuquerque@mbcpbank.com
Thank you!
104
