Solution for VoIP and PBX
Urban_Nights
Hi there,
I need a help from you, to have a solution with VoIP and PBXs.
So, I want to connect a VoIP machine to a PBX in order to send all the international calls towards this VoIP server.
The call scenario should be... analog phone --> PBX --> digit analysis (international) --> VoIP gateway --> other country call via IP.
Which equipment and what solution is better for this?
With best regards and thank you.
Hi, you need to know that, else you could end proposing a router with a number of ports that is too big or too small, that wouldn't be good I guess.
paolo bevilacqua
Which type and q.ty of pots lines the PBX have?
This is necessary to know in order to size the gateway.
thank you for your reply.
this is a Meridian Nortel PBX.
I really do not know how much pots lines do I have...but I know that we do not have a big traffic.
Regards.
Thank you for your answer.
I've to see the equipement fisrt, because I am in a remote side.
I'll let you know if I need something else.
Thank you and regards.
