Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
some extensions don't appear in CDR on callmanager
Dear All,
I have callmanager 4.2 and also I have Billing system but suddenly some extensions on callmanager don't appear on billing system.
I already extracted CDR file from the callmanager to insure if it recorded or not on the callmanager but I didn't find it in CDR file that means the problem in the callmanager itself.I restarted the CDR service but the same problem still exist.
Could anyone advice me how can I solve this problem.
Best Regards;
Re: some extensions don't appear in CDR on callmanager
Is CDR enabled in ALL servers in the cluster????
The setting is PER SERVER
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Only I have 2 servers on Publisher and the other one is subsciber and the CDR enabled only on publisher.but those extensions already were worked before on the billing system.
127
