Some international calls not going through
I have a CUCM 8.6 cluster with pub and sub and h.323 gateways in 2 locations. My pstn provider is the same in both locations. My issue is that when I call a number (some International numbers) from location A, the call goes through fine. However, caling exact same number from another location, the call fails. Following are the outputs of debug isdn q931 in both gateways. Can anyone tell me what could be the issue?
Location A where I have no problem calling the number in question.
VGW#
Oct 30 09:35:44.378: ISDN Se0/2/0:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num xxxxxxxxxx
Oct 30 09:35:44.382: ISDN Se0/2/0:23 Q931: Sending SETUP  callref = 0x2C0F callID = 0xA89C switch = primary-ni interface = User
Oct 30 09:35:44.382: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8  callref = 0x2C0F
        Sending Complete
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98390
                Exclusive, Channel 16
        Calling Party Number i = 0x2181, 'xxxxxxxxxx'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '011242066851476'
Oct 30 09:35:44.458: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0xAC0F
Oct 30 09:35:49.367: ISDN Se0/2/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x2C0F
        Cause i = 0x8090 - Normal call clearing
Oct 30 09:35:49.419: ISDN Se0/2/0:23 Q931: RX <- RELEASE pd = 8  callref = 0xAC0F
Oct 30 09:35:49.423: ISDN Se0/2/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x2C0F
Oct 30 09:35:52.383: ISDN Se0/2/0:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
Oct 30 09:35:52.383: ISDN Se0/2/0:23 Q931: Sending SETUP  callref = 0x2C10 callID = 0xA89D switch = primary-ni interface = User
Location B where I am having problem
VGW#
Oct 30 13:25:47.295: ISDN Se0/2/1:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
Oct 30 13:25:47.295: ISDN Se0/2/1:23 Q931: Sending SETUP  callref = 0x02D8 callID = 0x9112 switch = primary-ni interface = User
Oct 30 13:25:47.295: ISDN Se0/2/1:23 Q931: TX -> SETUP pd = 8  callref = 0x02D8
                Standard = CCITT
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Called Party Number i = 0x80, '011242066851476'
                Plan:Unknown, Type:Unknown
Oct 30 13:25:47.387: ISDN Se0/2/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x82D8
Oct 30 13:25:51.051: ISDN Se0/2/1:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x02D8
Oct 30 13:25:51.335: ISDN Se0/2/1:23 Q931: RX <- RELEASE pd = 8  callref = 0x82D8
Oct 30 13:25:51.335: ISDN Se0/2/1:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x02D8q
VIP Super Bronze
In location A, your isdn plan type is seen as this:
011242066851476
In location B, it is..
011242066851476
So it looks like your provider wants Plan:ISDN and Type: National
You can configure this on the gateway in location B
interface serial x/y:15
isdn map address ^011* plan ISDN type National
I am assuming that 011 is your intenational dialling code
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
I changed the plan type as you suggested but didn't help. The end of the q931 debug shows "no circuit/channel available".
Oct 30 16:48:47.570: ISDN Se0/2/1:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
Oct 30 16:48:47.570: ISDN Se0/2/1:23 Q931: Sending SETUP  callref = 0x02F8 callID = 0x9132 switch = primary-ni interface = User
Oct 30 16:48:47.570: ISDN Se0/2/1:23 Q931: TX -> SETUP pd = 8  callref = 0x02F8
                Standard = CCITT
Oct 30 16:48:47.658: ISDN Se0/2/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x82F8
Oct 30 16:48:57.158: ISDN Se0/2/1:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x82F8
        Cause i = 0x84A2 - No circuit/channel available
Oct 30 16:48:57.158: ISDN Se0/2/1:23 Q931: TX -> RELEASE pd = 8  callref = 0x02F8
Oct 30 16:48:57.206: ISDN Se0/2/1:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x82F8
Oct 30 16:48:57.982: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x0027
        Cause i = 0x8090 - Normal call clearing Oct 30 16:48:47.570: ISDN Se0/2/1:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
                Standard = CCITT
VIP Super Bronze
This error is different from the first set of logs. This log shows that your provider is disconnecting the call with no circuit available as the reason. You will need to engage with them and find out why you are getting this
Thank you so much. I will engage telco to get around this problem.
267
