Some sites phones are auto registering to old cucm
We upgrade from cucm 7 to cucm 8 and at sites which we have voice gateway and a router some phones are auto registering across the WAN to our old subscriber in our main site instead of our new subscriber . We had one of the phones sent to main site where the new subscriber is and the phone auto register to new subscriber.  Any suggestions?
1 REPLY
For that to happen you need to have auto-registration enabled, if you don't want or need that, disable it.
And also either the phone is looking at that server from the DHCP config it's receiving or it has been manually configured to point to that server.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
155
