sometimes ok and sometimes not ok......
hi,
I got a problem about mgcp GW and CUCM routing.
E1*2 DID------MGCP GW---------CUCM
all the ip phone are registered to the CUCM, and it is always ok for outbound calls from the ip phone to PSTN.
but when the PSTN call the DID numbers , sometimes ok and sometimes not ok......about 50% to successed.
I called the ISP to check the phone line, and they said they have sent the cg and cd number to the GW, and it seems no response, so the call failed.
and I can get the cd and cg number for the GW by debug isdn q931 both the call successed and not, so i think it maybe not the problems of ISP.
I have checked the isdn status, the L1 is active and line 2 is multiple established.
I checked the mgcp registered information and it seems ok.
and I checked the CUCM cpu status, it is about 5% usage.
and I checked the active calls number in GW, it is about 12, and i thought it is ok for E1*2
and I changed another E1 line (there are three E1 in the router) last Friday, it is not a DID line, and it is provided by another ISP,
I entered the following command for a translation.
voice translation-rule 3
rule 1 /.*/ /2288/
voice translation-profile 3
translate called 3
voice-port 1/0/0:15
translation-profile incoming 3
connection plar 2288
dial-peer voice 11 voip
destination-pattern 2288
session target ipv4:192.168.100.6
dtmf-relay h245-signal
codec g711ulaw
no vad
dial-peer voice 12 pots
incoming called-number .
direct-inward-dial
port 1/0/0:15
dial-peer voice 13 voip
destination-pattern 8...
session target ipv4:192.168.25.1
codec g711ulaw
no vad
dial-peer voice 22 voip
preference 1
session target ipv4:192.168.100.8
codec g711ulaw
no vad
dial-peer voice 9 pots
translation-profile incoming 2
translation-profile outgoing 1
service mgcpapp
destination-pattern .T
direct-inward-dial
port 1/0:15
dial-peer voice 10 pots
service mgcpapp
direct-inward-dial
port 1/1:15
voice-port 1/0/0:15
codec g711ulaw
no vad
direct-inward-dial
port 1/0/0:15
codec g711ulaw
no vad
preference 1
codec g711ulaw
no vad
service mgcpapp
direct-inward-dial
port 1/0:15
service mgcpapp
direct-inward-dial
port 1/1:15
I and shutdown the this E1 line and all the dial-peer, but when PSTN call the DID numbers, it is also sometimes ok and sometimes not ok.
I known my english could be better, but I hope you can understand what i said and you can share some advices with me.
thanks in advance.
yu.
  • IP Telephony
You need to start by degugging the GW to look at exactly who is disconnecting the call and what's the reason code.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
hi java,
thanks for your prompt reply,
I am MGCP packet code and I will use the debug mgcp packet command to find the disconnect reason tomorrow.
is there any other useful debug/show commands that I should use in that case?
thanks.
yu.
202
