10-23-2009 08:56 AM - last edited on 03-25-2019 07:53 PM by ciscomoderator
I'm trying to find a way to route inbound SIP calls, based on their source. For example:
SIPCarrier1 is coming from 1.1.1.1
SIPCarrier2 is coming from 2.2.2.2
If calls originate from SIPCarrier1, I want them to be passed to my UCM Cluster.
If call originate from SIPCarrier2, I want them to be passed to my Asterisk box.
I've played around with incoming called-number, trying to make it work with IP addresses, rather than phone numbers, but no luck.
Any ideas of where to start?
Thanx
Solved! Go to Solution.
10-23-2009 09:47 AM
10-23-2009 09:47 AM
Check Source VoIP Group:
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t11/feature/guide/ftgwrepg.html
10-23-2009 11:18 AM
Perfect! I think this is exactly what I was looking for.
Thank you.
10-23-2009 10:10 AM
Cisco CallManager uses SIP route patterns to route or block both internal and external calls.
https://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_0_1/ccmcfg/b03siprp.html
10-23-2009 10:33 AM
OP is asking about CUBE, not CM.
