SPA 500 AND SPA 300 SERIES IP PHONES
midhun_km
Dear all,
Good Monring....
Is it possible to SPA 500 AND SPA 300 SERIES IP PHONES to CUCM......?
or these phone made for only CCM Busuiness Edition Only....?
Goooood Day...
Midhun Kunnukattil Madhu
2 Accepted Solutions
ronpatel
Level 8
Level 8
Natively SPA500 and 300 are not supported in CUCM.
These phones supports standard SIP and SPCP (Tokenized Skinny), not SCCP.
So you can add them as third party SIP phone in CUCM.
But note these are still not tested to work with Cisco CUCM.
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Please rate post if it was helpful....
Cheers
Ronak patel
7 Replies 7
ronpatel
Level 8
Level 8
Ronak patel
Hi Ronak,
Is there any .cop.sgn device enabler available for these phone to directly adding to CUICM....???
Midhun KM
Unfortunately no, You can not add these phone natively to cisco CUCM.
Thanks...... RP....!!!!!!!!!!
Cheers
Ronak patel
hi Team,
Help me to check  if this SAP 301 model can add to CUCM version 4.2  as third party SIP phone?
Appreciate the Reply ASAP.
May
These phones are not tested to work with CUCM 4. But you may follow normal procedure to add third party phone and see if it works.
I do not have CUCM 4.2 to test it.
Ronak Patel
Rate helpful posts.
