SPA504G and SPA508G can support at Router CME
Recently, customer have purchase the Cisco 2921 come with CME and SPA504 IP phone.
I had configure the CME but I found the telephony service load firmware does not have above IP phone model and firmware. Can I know is it SPA 50x only can support by UC520?  How about the configuration in SIP,can it supported?
Thank you.
John
Hall of Fame Super Red
Re: SPA504G and SPA508G can support at Router CME
Hi John,
The SPA500 series of IP Phones are only supported with the UC520
540, 560 Small business systems
https://supportforums.cisco.com/docs/DOC-9551
3rd party SIP phones are not supported with CME.
Cheers!
Rob
Hi Rob,
Just making sure i understand correctly, the SPA504G is only supported on U5XX and not Callmanager express on cisco 2800/3800/2900 routers?
I though SPA504G supports SIP? if it supports sip, then i am under the impression that it should be able to register the SPA504G.
Have UC320 that i wanted to replace and was hoping 2800 configured CME might be useful.
Thanks.
Jeff
Hi All,
trying to find a way to communicate to support but having a hard time figuring out how one a topic.
Anyway somehow related to SPA 504G phones.
My SPA 504G Phones suddenly started rebooting and asking for password for simple scrolling of menus
voicemail pin doesnt work either.
I factory reset my phone and then after 2 days goes back to the same issue.
can you advise what resolution I can make?  My phone system hasn't change any configuration
neither have updated either.
Hope anyone can help.
Noel V.
SNET COMMUNICATIONS
Chicago
2521
