spa962 wont configure via tftp
Scope:
Get a spa 962 to retrieve a config file from a server using tftp or http, and properly take up the settings.
Users have reportedly done it, but the documentation from cisco has nothing whatsoever.
Anyway,
The xml config for the phone can be reached at:
http://<ip_address_of_phone>/admin/spacfg.xml
I visited that url of an already working spa962, then saved the file changed the extension to a different number.
I then loaded it to the tftp server, and changed the name to include the mac address as specified, with all capital letters:
spa<mac_address_all_caps>.cfg
I then verified that tftp was working
tftp <ip_of_tftp_server>
get spa<mac_address_all_caps>.cfg
success
( just for kicks I put a copy in the web root to try http provisioning as a backup resort )
So, the only thing left was to point the phone at its config file.
I went to the phones web gui, went to the "provisioning" tab,
I then changed the "Profile Rule:" field
original value: /spa$PSN.cfg
to:
<ip_of_tftp_server>/spa$PSN.cfg
tftp://<ip_of_tftp_server>/spa$PSN.cfg
http://<ip_of_tftp_server>/spa$PSN.cfg
<ip_of_tftp_server>/spa$MA.cfg
tftp://<ip_of_tftp_server>/spa$MA.cfg
http://<ip_of_tftp_server>/spa$MA.cfg
<ip_of_tftp_server>/spa<full_typed_out_mac_address>.cfg
tftp://<ip_of_tftp_server>/spa<full_typed_out_mac_address>.cfg
http://<ip_of_tftp_server>/spa<full_typed_out_mac_address>.cfg
absolutly nothing,
Then I found you could force feed the phone new configs
http://<ip_address_of_phone>/upgrade?tftp://<ip_of_tftp_server>/spa<full_typed_out_mac_address>.cfg
Still defiant,
It should have read the file, and accepted the new xml settings which were identical except for the extension number.
Why didnt it upload the new file and accept it?
Re: spa962 wont configure via tftp
Hi uleave hudson,
I replied to your other thread, but take a look at this document https://supportforums.cisco.com/docs/DOC-9954 starting page 9 where I describe how the phone resolves spa$PSN.cfg Continue reading through page 13 and you should now be able to succeed with your exercise.
Pages 14-22 show the WireShark traces of what the phone looks for and how it reacts. Your SPA962 behaves in the same way as the SPA525G that I used to write this paper.
Best of luck, it really does work.
Patrick
You only need one reference document for all SPA phone firmware, information, and utilities.
Can anyone direct me to the fabled DOC-9954 , this link does not go anywhere ?
Thanks in advance
Paul
688
