Spain PRi configuration
Hi all,
does anyone knows what are the paremeters for configure a Pri line throught MGCP in a Callmanager?
(PRI Protocol Type, line codinf, framing, ...)
thanks in advance
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Spain PRi configuration
Like all European contries, switchtype primary-net5, linecode hdb3, framing usually crc4.
hope this helps, please rate post if it does!
that's correct, the problem was that I selected a T1 interface instead E1 one. therefore this parameters didnt appear. Now it's correct.
thank you very much for your faster answer.
You're welcome, please remember to rate posts using the scrollbox below!
thanks again,
Do you Know how can I receive all calls (from this Pri line) in a Line Group?
The MGCP gateway is configured.
The line group is Configured.
126
