span to PC port on CME
Is there a way to enable "span to PC port" on CCME for 7941 phone?
Thanks!
Silver
Re: span to PC port on CME
You can get to this parameter by pressing settings button on the set, then 3 then 6. This is Ethernet parameter. As a default is set to 'no'
On a CME many options are configurable Globaly.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_s1ht.html#wp1132500
You may check out the command reference giude and table 17 in this for vaiours options.
To answer your question in short,
Under telephoney service.
service phone spanToPCPort 0
This should work.
Hope this helps.
Make sure to issue the create cnf command under telephony-service  after making the change. You'll then need to reset the phone in order for the change to take effect.
-Felipe
Its been old post, Im wondering, do we have to follow same procedure to capture packets for SIP phones ? or configuration needs to be done under voice register global ?
Yes, the same process works
Yes, the same process works for SIP phones. Just make sure to issue the "create profile" command under "voice register global" after setting the parameter under "telephony-service"
-Felipe
2921
