spanish locale in 6921 with cme 8.6
I am looking for in support if is possible update the ip phone 6921 sccp to spanish locale in a CME 8.6,
thanks!
1 ACCEPTED SOLUTION
Blue
Yes it is supported
You can download the locales and configure as shown in below link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_u1ht.html#wp1014738
Locale files will be in CME download section.
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
1 REPLY
Blue
Yes it is supported
Ronak Patel
Rate helpful posts.
272
