Community Member
Special Ringtone when specific numbers dial
I have a scenario that requires a 2 7965 Devices at Room A to ring with a special ringtone only when devices from room B call them. ( All are CUCM Lines).
Is there any feature that can answer this req?
I've searched for MLPP, but i can't see where this helps.
Thanks in advance,
SC
No, there's no way to configure ringtones based on calling party.
You can only have different ringtones if you're using different lines, if you can configure more than one line on the device create a DN which only room B can reach and configure a different ringtone on the phone for that line.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
Hi Java,
Thanks for the quick reply.
Best Regards,
191
