02-02-2012 01:51 AM - edited 03-16-2019 09:21 AM
Hi ,
i would really appreciate if some body can assist in getting the updated and current information on conference phone 7936G, for which i have a document but is a little outdated. We are in the process of procuring a large number of phones , so it is important for us to get the correct info. Any help would be really appreciated.
Abhishek
Solved! Go to Solution.
02-02-2012 02:03 AM
Abhishek,
Did you check out the ordering guides listed here http://www.cisco.com/web/partners/sell/technology/ipc/uc_tech_readiness.html ?
The portal has ordering guide for IP Phones as well.
GP.
Pls rate helpful posts !!
02-02-2012 02:03 AM
Abhishek,
GP.
02-02-2012 02:38 AM
Thanks.
02-02-2012 05:23 AM
Hi Abhishek,
Just thought I might add this link You'll probably want to go with the 7937G
they are far nicer (and cleaner to connect) anyways
End-of-Sale and End-of-Life Announcement for the Cisco Unified IP
Conference Station 7936
Cheers!
Rob
02-02-2012 11:13 AM
Gee !!! Thanks you are the Man Buddy
