Speed-Dial codes/abbreviated dialing
tomearley
Greetings.  Can anyone tell me if it is normal for the speed-dial code/abbreviated dialing soft key to be greyed out when the user is on a call?  Many thanks!
6 Replies 6
Chris Deren
Which state is the phone exactly?
AbbriviatedDial is not an option for Connected state.
Chris
Hello Chris,
Yes when user is on a call, abbrv dial softkey is greyed out. So if I understand you correctly, abbv dial is not an option when call state is active/connected?
Thanks!
Tom
Chris,
Why would it not be an option? what is the reason.
Thank you!
Tom
Tom,
What exatctly are you doing on the phone, are you in Connected state or in Off Hook With Feature (pressed conference or transfer)?
If the first then it is not impossible to invoke AbbDial as you are simply talking to another party, if the second then the softkey should be available if defined in softkey template and as soon you enter digits i.e. 1 AbbDial should become available (un grayed out).
Chris
Thank you Chris.  I have been unable to locate Cisco Docs that specify these details- any suggestions?
Tom
Sure, have a look at the System Guide and Admin Guide for your CUCM version:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_maintenance_guides_list.html
HTH, please rate all helpful posts!
Chris
