Community Member
speed dialing
I have a ccme 3.3 and 20 IP phones. I want that all the phones can dial to a number i.e. 200 and then this number translate to a external number i.e. 964812510
That is the most dialed number in the office so I want that all users dial it faster.
Is it possible to configure it in the cme? How can I do it?
Hall of Fame Super Red
Re: speed dialing
Hi Santi,
This is quite possible in CME here are some docs that explain the methods;
Speed-Dial Buttons and Abbreviated Dialing
In a Cisco CME system, each phone can have up to 33 local speed-dial numbers (codes 1 through 33), up to 99 systemwide speed-dial numbers (codes 1 through 99), or a combination of the two. If you program both a local and a systemwide speed-dial number with the same code (tag number), the local number takes precedence. In most cases you will want to reserve codes 1 through 33 for local, per-phone speed-dial numbers and use codes 34 through 99 for systemwide speed-dial numbers so that there is no conflict.
On an IP phone, a speed-dial number can be on a speed-dial button or it can be an abbreviated code that is dialed from the keypad. On an analog phone, a speed-dial number can only be an abbreviated code.
Each speed-dial definition contains a speed-dial code (an identifier also known as a tag) and usually the full extension or telephone number that should be dialed when the code is used at the phone. However, local speed-dial entries on IP phone buttons can be defined without telephone numbers so that phone users can enter whatever numbers they want from the phone. Local speed-dial definitions can also be created with locked numbers that cannot be changed from the phone. Systemwide speed-dial definitions cannot be changed from the phone.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00804ad85d.html#wp2230559
Here is a good overview doc for the different CME Speed Dials;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00804ad85d.html#wp2294210
Hope this helps!
Rob
Community Member
Re: speed dialing
If you want/have to use the dialed nr. 200 you
can use global translation-rules on the ephone-dn.
Like:
translation-rule 10
rule 1 200 964812510
ephone-dn xx
number xxxx
translate {called | calling} 10
Greets,
Norbert
Community Member
Re: speed dialing
What I want to do is :
If an IP phone dial 200 it is translated automatically to the number 667422712 who is the number of the head office of my company
I have tried to do what you say but its not running and then I have tried this:
ephone 1
speed-dial 20 +667433712 label headoffice
then restart
But it's not running, any ideas?
Community Member
Re: speed dialing
When you dial (from the phone directly) the number 667433712, does it work's?
If not, you may haven't a dial-peer for this nr.
Greets
Norbert
Community Member
Re: speed dialing
Yes I have a dial-peer for this number and if I dial 667433712 directly it works.
Community Member
Re: speed dialing
I used the following to force divert all "0" calls to the recpetionist on ext 300
ephone-dn 100
number 0
label Internal reception
call-forward all 300
By the same logic, this should work too
ephone-dn 200
number 200
label Head-Office Transfer
call-forward all 667433712
As long as the person who dials 200 has the required Class of Restriction to use the number that the call-forward points to, should work.
Steve.
Community Member
Re: speed dialing
here a sample with translation-rule:
translation-rule 200
Rule 1 ^200 667433712
ephone-dn 1
number 220
label nr.220
name nr.220
description nr.220
translate called 200
Greets,
Norbert
172
