09-12-2007 12:04 AM - edited 03-14-2019 11:29 PM
Morning all. Can anyone point me in the direction of configuring speed dials under CME? I can configure the local directory easily enough, but cant seem to find anywhere to configure speed dials.
09-12-2007 02:43 AM
Heres a link that might be helpful
http://www.cisco.com/univercd/cc/td/doc/product/voice/its/cmeadm/feat/cmespeed.htm#wp1010364
If you need help on configuring bulk speed dial lists I can provide an example for that also
09-24-2007 11:10 PM
One way is that you configure speed-dial numbers on router through CLI. Also the same for fastdial numbers. The other way, if you want to alow users to edit their fastdial numbers, you assign username/password to ephone, and then user log in through web GUI hxxp://ip-address/ccme.html
