Speed dials for Callmanager Express
I'm implementing a Callmanager express for a client and i'm experiencing a problem. I configured speed dial on a 7961 IP phone. The speed dial shows agains some of the botton on the phone and does not show on other botton. Despite the same commands for all bottons. What could probably be the cause? Pls help.
Hall of Fame Super Gold
Re: Speed dials for Callmanager Express
Hi, speed-dial will show only if you have free unused buttons, and the number used does NOT define the button that will be used, is that your case ?
Hi Peternnaji,
How are you programming CME? Through the console or web interface?
Try doing this with the web interface. It's much easier.
HTH, Please vote below for my post.
Justin Brenton
I'm programming thriugh console but how do i go into the web interface?
Hi friend,
Check this link to enable the GUI for CallManager Express:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmegui.html
Hope this helps a little bit.
-- Adrián.
126
