Speed Dials
How do users use the speeds dials they setup through the user web interface?
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Speed Dials
Hi Taylor,
The Speed Dials that are configured by the User via ccmuser are associated with spare Line Buttons (if any are available)and the remainder are accessed via the AbbrDial Softkey (Abbreviated Dial) In this test scenario the 7961 has a Button Template called 3-Line 3-Speeddial so the first 3 that are setup via ccmuser take Line Button 4,5 and 6. The remainder are accessed by keeping the Handset On-Hook, dialing the applicable Speed Dial Code (for example 15 followed by pressing the AbbrDial Softkey) the number programmed against Speed Dial 15 will then be called;
The following options are available for SEP00170EEE2F88 (Test Q335):
Forward all calls to a different number
Add/Update your Speed Dials
Configure your Cisco IP Phone Services
Configure your Cisco Personal Address Book
Change the Message Waiting Lamp policy for your phone
Change the Ring Settings for your phone
Change the Locale for this phone
Change the Locale for these web pages
Change your Password
Change your PIN
Add/Update Your Speed Dials
Configure the Speed Dial Buttons for your Cisco 7961 (SEP00170EEE2F88)
Use this page to enter the phone numbers you want associated with each of your Speed Dial buttons. When you are done, click Update.
Hope this helps!
Rob
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
1 REPLY
Re: Speed Dials
Hi Taylor,
Change your PIN
Hope this helps!
Rob
414
