07-03-2008 05:58 AM - edited 03-15-2019 11:43 AM
I'm in process of separating a single CM cluster in to two. Is there a way we can find speed dials in each phone by running some SQL queries. In other words I just want to know who has speed dials configured on their phone. Instead of going to each phone if I know who has this SD I'll go to their phone and manually configure instead of checking each phone.
Thanks for your help in advance.
07-03-2008 11:27 AM
if you're going to have the 2 clusters on the same version what you can do is perform a bat export with all details.
you will see in the file who has speed dials configured and also can use it to import them to the new cluster with almost all the config. maybe change partitions or something like that but most config will be on the file.
javalenc
if this helps, please rate
07-03-2008 11:34 AM
It is two different versions one is 4.1 and new cluster is 6.1. I'll still export and see how many I have to do if it is not that many I might do it manually.
Thanks for your help.
