spurius lines in CUBE show log
in my show logging i found lots of line like this
"log VCC, mtp1 index, mtp2 index, stream1, stream2 = 0 0 135 136 VCC, mtp1 index, mtp2 index, stream1, stream2 = 0 0 136 135"
these lines overlap normal logging make it unreadable ... these lines appear in conole or vty (terminal monitor) too ...
i do not have any debug enabled and for safety i have done an "undebug all" command in CLI
it seems that trace output is relate to incoming calls and that numbers (135, 136 in the exemple) is such a kind of counter ...
is a cosmetical bug ?
Any suggestion to have a clean log ?
Thank you very very much in advance.
Regards.
26
