Community Member
SQL help in 6.1
Is there a doc that shows the different "object column headings" (excuse my terminology) or parameters that you can search on in 6.1. In 4.2 I could pull up with SQL Query Analyzer all the columns in CallDetailRecord.
From there I can write a query to include only the colums I want to see ie: calledparty, duration, callingparty...
Thanks.
1 REPLY
Re: SQL help in 6.1
look at the data dictionary for your version
Programming Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_programming_reference_guides_list.html
java
if this helps, please rate
java
www.cisco.com/go/pdi
189
