Community Member
SQL job error
Hello!
After upgrading to 4.1(3)SR4d from 4.1(3)SR2 2 SQL jobs drops error:
- Monitor Disk Space on the publisher at TruncateCCMLog Step. The truncateCDRLog step is OK.
- Expired Subscription Clean up.
The error messages:
Event Type: Warning
Event Source: SQLSERVERAGENT
Event Category: Job Engine
Event ID: 208
Date: 2/6/2007
Time: 10:00:03 AM
User: N/A
Computer: HS001CCM1
Description:
SQL Server Scheduled Job 'Monitor Disk Space' (0xFF7F864070DD154988F7BB7DD41D48FE) - Status: Failed - Invoked on: 2007-02-06 10:00:02 - Message: The job failed. The Job was invoked by Schedule 38 (Schedule 1). The last step to run was step 2 (TruncateCCMLog).
and: Got no error message, I have just set the job to send messages to the event viewer.
Do anybody knows what to do?
Bela
1 ACCEPTED SOLUTION
Re: SQL job error
-Doing the restore with a backup containing a CCM database name of CCM0301 or higher (The database name starts at CCM0300 and increments for major CCM upgrades).
Workaround:
-Open SQL Enterprise Manager
-Expand Microsoft SQL Server -> SQL Server Group -> local -> Management -> SQL Server Agent -> Jobs
-Right click the "Monitor Disk Space" job on the right, and select Properties.
-Click the Steps tab
-Click Step 2 (TruncateCCMLog)
-Click Edit
-Copy the contents of the Command window into Notepad
-Do a search/replace, replacing all instances of CCM0300 with current CCM database (for example, CCM0302)
-Copy all the corrected text to the clipboard, then paste it back into the Command window, overwriting the old, incorrect text.
Further Problem Description:
The issue occurs because the Monitor Disk Space SQL job isn't updated to reflect the correct, current CCM database name after a BARS restore is done. Therefore, if the restored CCM database name is anything other than CCM0300 (already listed in the job from the clean CCM install), it will continuously fail.
If you have the correct DB then check the owner of the CCM030X database: go to SQL Enterprise manager, right click on the
CCM030X database and then properties; check whether owner is
\Administrator.
If the Owner is empty, then you need to run the following SQL statement to reset the owner
of the CCM030X database. So go to the SQL Query Analyzer, from the database drop down list select database CCM030X and then run the following query. The should be
machine's hostname:
sp_changedbowner '\administrator'
Community Member
Re: SQL job error
The second error message is:
The job failed. The owner () of job Expired subscription clean up does not have server access.
Unfortunately the owner of the job is the Administrator...
regards,
Bela
Silver
Re: SQL job error
We had the same issue after Restoring a System using BARS, check the Bug CSCsg32819 to resolve it.
hope this helps.
Community Member
Re: SQL job error
This is somewhat different, the database name is ok.
regards,
Bela
Re: SQL job error
Workaround:
-Click Edit
\Administrator.
machine's hostname:
Re: SQL job error
And also check the owner for the CDR database
Community Member
Re: SQL job error
This error have occured once before, unfortunatelly I have forgot the statement how to change it.
It is interesting CDR truncate dropped error only a few time, while CCM truncate dropped error every time when the scipt was running.
Be?a
Community Member
Re: SQL job error
Did you ever got this issue fixed because I have the same problem .I didn't do anything at all it just stopped please let me know if you have fixed this issue.
Bala
Community Member
Re: SQL job error
yes, this solved the problem, that's why I rated the post extremely helpfull.
Bela
Community Member
Re: SQL job error
Well our server is not hitting that bug because it was not a restore it just stopped couple of weeks back.I still checked the database name and it is the current database name and number.
For us it was working fine and it just stopped CM ver is 4.1.3 sr3a.
What was your fix?Is that the same bug or is it different?
Let me know and thanks for quick response.
Bala
257
