SQL Query for ELM/PLM licenses Required, Installed and Available
Support Forum,
I have been writing test SQL queries against the 'licensingresourceusage' and 'licenseserver' from the UCM Data Dictionary 10.0 and have not come across a method to retrieve total licenses, either 'Required', 'Installed' or 'Available' in ELM/PLM.
I have retrieved licenses allocated to an enduser e.g. tin, copper, bronze, etc.  But I cannot find the overall license summary.
Does the ELM/PLM run a separate dB with no SQL access? or I am not using the correct command syntax for the given tables in the UCM 10.0 Data Dictionary.
Any suggestions would be greatly appreciated.  Thanks.
1 ACCEPTED SOLUTION
VIP Purple
Hi, check this link for
check this link for license calculation using SQL queries
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/117600-technote-cucm-00.html
regds,
aman
VIP Purple
regds,
aman
aman,this is a great article.
aman,
this is a great article.  Many of the SQL queries I have done are included with this doc.  I was definitely on the right track.  I have no digested all of the doc...but from initial scan it seems right on track.  I appreciate the assistance.
David
204
