VIP Purple
SQL Query to find DN and phone Load
Hi All,
We are using Call Manager 8.6 [one PUB and 4 SUBs] and have different IP phone models .
IP phone model have different LOAD working with them like few 3905 have cmterm-3905.9-2-2-0 while some have cmterm-3905.9-2-2ES7 .
Is there any way/SQL Query  to find out what all phone model with DN are running 3905.9-2-2.0 LOAD?
regds,
aman
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Hey Aman, Hope all is well my
Hey Aman,
Hope all is well my friend!
Just to add a note to my friend Carlo's good info here (+5!)
Try;
Device> Device Settings> Firmware Load Information>Device Not Using Default Load
This will show you any phones that deviate from the "device defaults" Fimware And if you click
on any device listed here it will show the actual Firmware that is being used on the specified device.
Cheers!
Rob
Hi Aman.you can also try run
Hi Aman.
you can also try run sql select d.name, d.specialloadinformation, d.description, n.dnorpattern as DN from device as d,numplan as n, devicenumplanmap as dnpm where dnpm.fkdevice = d.pkid and dnpm.fknumplan = n.pkid and d.tkclass = 1 and d.specialloadinformation != '' and d.tkmodel = '592'
which means, give me all 3905 which has "Load Information" field NOT empty and tell me what is written there :)
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Aman.Because cmterm-3905.9
Hi Aman.
Because cmterm-3905.9-2-2-0 is the default load, other phone running different load should have "Load Information" field filled out on phone configuration page.
With the below query, we get all 3905 phones with that field blank (the db field is specialloadinformation)
Try this query
run sql select d.name, d.description, n.dnorpattern as DN from device as d,numplan as n, devicenumplanmap as dnpm where dnpm.fkdevice = d.pkid and dnpm.fknumplan = n.pkid and d.tkclass = 1 and d.specialloadinformation = '' and d.tkmodel = '592'
Carlo
VIP Purple
Hi Carlo, thanks for the
Hi Carlo,
thanks for the reply.
Let me check tomorrow.I will get back to you.
regds,
aman
VIP Purple
Hi Carlo, [+5] I checked the
Hi Carlo,
[+5]
I checked the same.
But my query was to find out different loads being used by same IP phone model.when I run the query , entering load I get no output related to 3905 Specific LOAD
run sql select d.name, d.description, n.dnorpattern as DN from device as d,numplan as n, devicenumplanmap as dnpm where dnpm.fkdevice = d.pkid and dnpm.fknumplan = n.pkid and d.tkclass = 1 and d.specialloadinformation = 'CP3905.9-2-2-0' and d.tkmodel = '592'
or
run sql select d.name, d.description, n.dnorpattern as DN from device as d,numplan as n, devicenumplanmap as dnpm where dnpm.fkdevice = d.pkid and dnpm.fknumplan = n.pkid and d.tkclass = 1 and d.specialloadinformation = 'CP3905.9-2-2ES7' and d.tkmodel = '592'
If I leave the specialloadinformation as blank, I get all 3905 IP phones.
Please advise how can I get this info.
regds,
aman
Hi Aman.
Carlo
VIP Purple
Sure Carlo. I would try this
Sure Carlo.
I would try this as well and update u.
regds,
aman
Thanks Aman....and +5 to my
Thanks Aman.
...and +5 to my friend Rob!
Long time :)
Cheers
Carlo
VIP Purple
thanks to dear Rob and Carlo.
regds,
aman
Hey Aman,
Try;
Cheers!
Rob
VIP Purple
Sure Rob.. I will check on
Sure Rob..
I will check on Monday and update u.
regds,
aman
350
