VIP Purple
SQL query to find IP addresses in CUCM
Hi ,
we are using CUCM version 7 and need to find the IP addresses of applications like Unity connection, UCCX,Third party billing server  by running SQL instead of seeing through GUI.
Please advise.
regds,
aman
1 ACCEPTED SOLUTION
I haven't worked with Biling
I haven't worked with Biling Software and hence can't comment on that. Anything that you see under 'System > Application Server' should show up in the appserver table.
Try this,run sql select name,
Try this,
run sql select name, ipaddr from appserver
VIP Purple
Anirudh,I would try and get
Anirudh,I would try and get back to you.
regds,
aman
VIP Purple
Hi Anirudh, Bit confused.
Hi Anirudh,
Bit confused.
What do we need to write in  name  under query?
If possible, can u share any working snapshot on the same.
regds,
aman
admin:run sql select name,
admin:run sql select name, ipaddr from appserver
name             ipaddr
CUC8            10.x.x.x.
CUC9            10.x.x.x
This will give all entries under System > Application Server.
VIP Purple
Hi Anirudh,I tried running
Hi Anirudh,
I tried running the command  and got output only for Call managers in a cluster.
Can't I get for third party servers which are integrated with CUCM like Billing Software?
regds,
aman
173
