SQL Server Authentication
I am trying to install the CDR Plugin but it ask me for a SQL Username and password that I ignore. SA is commonly used as the username but I still miss the password. How can I reset it or recover it?
1 ACCEPTED SOLUTION
Re: SQL Server Authentication
CHeck the section, Reset SQL SA password section
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008014f8e8.shtml
Sankar
PS: please remember to rate posts!
Sankar
Thank you very much
Hi thisisshanky,
I got a problem when install CDR plug in on CCM 3.3. It asked me for a private phrase, I even put the administrator pass and even reset all password by using Admin Utility. But it did not help. Can you give me some clues?
Thanx
95
