SRE -> CUE 8.6.6 -> not reachable only from router
i have a strange issue with a CUE module. Its a SRE 710. If i configure the following i can reach the CUE module from internal clients:
interface Loopback0
description "CUE TESTING TEMP"
ip address 192.168.20.1 255.255.255.0
end
interface SM1/0
description Unity-Express-Module
ip unnumbered GigabitEthernet0/0
ip virtual-reassembly in
service-module ip address 192.168.20.10 255.255.255.0
!Application: CUE Running on SM
service-module ip default-gateway 192.168.20.1
end
But if use the gi0/0 as unnumbered its not working
interface GigabitEthernet0/0
ip address 10.224.0.251 255.255.255.0
ip virtual-reassembly in (tried without)
duplex auto
speed auto
end
interface SM1/0
service-module ip address 10.224.0.249 255.255.255.0
service-module ip default-gateway 10.224.0.251 (or def gw)
end
I have tried to reload the module and also the router. No success. Only with looback. But i need to do it with the same subnet as router. Any suggestions?
Thorsten
1 ACCEPTED SOLUTION
Another advise, what IOS are you using?
There is a similar post already:
https://supportforums.cisco.com/thread/2219939
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Well, most of the time this issue is related to routing. Does the default gateway of the network knows that ip
10.224.0.249/24 is reachable behind 10.224.0.251/24?
You could setup a static route:  ip route 10.224.0.249 255.255.255.255 10.224.0.251, and this is just an example.
There migth be several reasons for the issue, but I'll first look at routing.
Jorge Armijo
Jorge Armijo
I`m using this IOS. Thanks Jorge. Hope there will be an update soon.
Tthorstenn,
Here's the bug ID for the problem
CSCuh87899 : IP connectivity lost with the SRE Module after upgrading IOS to 15.3(2)T
Now is just a matter of time...
Jorge Armijo
Thanks Jorge. But the link says "no  known BUG" :-/
Hm i got the following:
The bug ID  does not exist.  Please verify the bug  ID and try again. If you feel you reached this message in error, please  send us feedback including the bug ID in question. Thank you.
I'll let you know when it becomed visible
Jorge Armijo
For now you can move away from that IOS, in order to not be affected for the defect.
Jorge Armijo
265
