Community Member
SRST 8.0 and Multiple (5) MOH Local Sources
Has anyone utilized the new multiple MOH sources in SRST 8.0 - was looking for an actual configuration when SRST is in standby mode (using CUCM for MOH - spoofing).  I have downloaded the new SRST 8.0 MOH Enhancement/New Features Guide, but it is sort of lacking on the CUCM configuration side to get the 5 sources to work on the local SRST router.  I do know the sources must reside in the flash memory of the router and moh voice groups configured to point to each of those flash files as well as a incremental multicast IP addresses that must correspond to the sources in CUCM.  Just not sure if CUCM will actually support the mulit source or not.
Thanks.
Community Member
Re: SRST 8.0 and Multiple (5) MOH Local Sources
Update - this new localized MOH configuration actually works quite well with multiple sources from the router flash.  The problem
now is that there are issues with using this type of configuration with the 69xx IP phones.  Works fine with the 79xx IP phones.  So, a new TAC case has been opened to take a look into why the 69xx series are not responding correctly to the streams.
Community Member
This is actually a new bug with the 69xx IP phones....
BugID: CSCte80922
What Changed: Bug Status, Headline, Fixed in version, Bug Details, , Severity
Title: 6941 plays ToH when Multicast MoH is sourced from a SRST 8.0 router
Technology: nav
Version: 8.5(4)
Fixed-in:
Severity: 3
State: Assigned
Bug Details:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCte80922
BTW, these phones are sourced from a 3rd party developer out of Taiwan, so fixes and updated firmware could take longer than usual.
-Jeremy.
332
