10-01-2010 12:25 AM - edited 03-16-2019 01:07 AM
c2900-universalk9-mz.SPA.151-2.T1.bin
CONFIG (Version=8.1)
Version 8.1
Pure H323 setup. Reference set in call manager. Phones just go in loop saying registering. I can see that default gateway is the router itself in phone. All 7942 phones with firmware sccp 42.8-5-3s
Any ideas/suggestions/bug reports appreciated
10-01-2010 12:31 AM
Perhaps start by posting your configuration.
Aaron
10-01-2010 01:04 AM
call-manager-fallback
secondary-dialtone 0
max-conferences 4 gain -6
transfer-system full-consult
timeouts interdigit 3
ip source-address 192.168.255.25 port 2000
max-ephones 24
max-dn 50 dual-line
system message primary SRST
default-destination 298
voicemail 6148
moh ivision_new.wav
multicast moh x.x.x.x port 16384 route 192.168.255.25 192.168.60.1
time-zone 48
time-format 24
date-format dd-mm-yy
05-03-2011 07:09 AM
Hi Aman!
I'm running into this same exact issue, TAC doesn't seem to have an answer for it. Were you able to determine the issue and did you find a work around?
Thank you...
05-03-2011 03:57 PM
Hi Mate
As far as i remember, i had a wrong srst reference set in the call manager device pool. was a silly mistake. You might want to post your configuration and check the srst reference.
Cheers
Aman
