SRST Access code
i beleive i have read it somewhere on the forum before but i could not find it again.
I have CCM 4.13 and VG 2811 in SRST fall back.
Normal behavior, end user dials 9 for access code and hear tone as soon as he dials 9.
in SRST mode (i configured the access code 9 of course) it takes long time to hear back the tone and the end user feel something wrong (it could take like 7 seconds).
Is there any way to reduce this timing?
Good day
2 ACCEPTED SOLUTIONS
Gold
Re: SRST Access code
under the SRST config, can you try "secondary-dialtone 9" and see if that helps
The delay is because of the 9T configured in the Dial-peer. By configuring 9T, the system waits for the inter digit timeout. I think the default value is 10 second. Try the following:
Dial-peer voice 1 pots
Description Local Calls
destination-pattern 9[2-9].........
port 0/0/0
forward-digits 10
Dial-peer voice 2 pots
Description Long Distance
destination-pattern 91[2-9].........
port 0/0/0
forward-digits 11
This is an example for local and Long Distance calls. You need to configure a Dial-Peer matching the international calls as well.
Gold
sounds more like u have an overlapping Dialplan. Do a show dial-peer voice summary and check for the overlap. The best option is to aviod overlap instead of playing with timers
uhmmm,
well i have more than one dial peer with each point to an FXO (Voice port).
destination-pattern 9T
port 0/0/0
Gold
can u attach the output of "show dial-peer voice summary" and "show call-manager-fallback all"
Hi Mahesh,
I will send them tomorro as i have no access to my customer's remotly.
thanks Mate for your help
Good day
Attached are the files you asked for.
Good day
Gold
port 0/0/0
forward-digits 10
port 0/0/0
forward-digits 11
The secondary dial tone did the JOB.
Thanks and Good day
205
