Community Member
SRST and ATA
if I'm on SRST mode the ATA won't register with the GW, is there a few lines that I'm missing or what should I do in order to get the ATA to register with CCM
I have a 2851 GW running Version 12.4(3h)
Community Member
Re: SRST and ATA
To start with the easy stuff...do you have your ATA's in the same device pool as your phones. If not make sure the device pool they are in have the proper SRST reference.
Community Member
Re: SRST and ATA
Yes, my ATAs have the same Device Pool as my phones
Community Member
Re: SRST and ATA
Are they in the same VLAN as your phones, and are you using "strict-match" in the "ip source" statement for call-manager-fallback?
Community Member
Re: SRST and ATA
I'm not using the strict-match
this is what i have
ip source-address 10.12.10.9 port 2000
Community Member
Re: SRST and ATA
Is it in the voice VLAN? If you are using "Default Gateway" for SRST, you need to make sure that the default gateway is the gateway with SRST on it...
Community Member
Re: SRST and ATA
yes, the ATAs are in the voice vlan
I'm not using a default gateway
secondary-dialtone 9
max-conferences 8 gain -6
max-ephones 75
max-dn 100
transfer-pattern 7070..
voicemail 919169333324
moh music-on-hold.au
multicast moh 239.1.1.2 port 16386 route 10.12.10.9
Community Member
Re: SRST and ATA
I am having the similar issue although the IOS is latest...Were you ever able to figure this out?
Thanks in advance
Community Member
Re: SRST and ATA
No, not yet
224
