SRST and ESRST
I am working on new Cisco Voip implementation. I recently learned that the new SRTS mode can support up to 1500 users in failure mode.
The question I have is, if I have 2 routers, can I have some users get priority to register in case of failure to one SRST router, and everyone else will fight over the other router. I want to make sure my executives are happy.
1 REPLY
SRST and ESRST
Hi.
The first thing I can suggest, is to configure two Device Pool with two different SRST reference.
In this way IP Phones on Device Pool A would register on Router A and the others in RouterB.
With different Device Pools, you can also balance ip phones registration between CUCM in the cluster.
Carlo
Please rate all helpful posts "The more you help the more you learn"
84
