SRST and forward number
webstd.design
When phone with forwarded mobile number goes in SRST mode,will phone call forwarded mobile number in SRST mode?
Thanks!
6 Replies 6
Michael Owuor
Hello Alexandr,
CFA settings are not retained in SRST. The database on CCM handles the call forward setting, and the phone itself does not store the call forward settings, so any CFA settings are not carried over when the phone goes into SRST mode.
Let me know if this answers your question.
Michael.
How can I use CFA or something like this to transfer call from GW to mobile phone when GW is in SRST mode??
You could use the call-forward pattern 9. in call manager fallback mode....
I didn't understand your answer? Can you explain in more detail?
You may have to double check the syntax using the help.....
>conf t
>call-manager-fallback
>call-forward pattern 9T
Let me know if it helps!
If user from PSTN call city number 5551234 when GW is in SRST, I use translation pattern to translate number 5551234 to internal number 1234 on voice-port.
but if I want, when GW goes to the SRST mode, and user call from PSTN internal number 1234, what should I write to forward call from 1234 to
PSTN number?
