SRST and UCCCX
We have a CUCM Business edition ver 7.0
and srst ver 7 voice gateway with UCCX ver 5.0
In event of Business edition failing, we have got SRST configured on the Gateway.
Is there a way that I can configure the voice gateway to be able to use the UCCX.
2 ACCEPTED SOLUTIONS
Re: SRST and UCCCX
Personally, I would consider using the B-ACD TCL script on the gateway. That way you can have resilience against UCCX failure as well (or even get rid of it completely :-)
Hall of Fame Super Silver
Re: SRST and UCCCX
Unfortunately it's not that simple as UCCX does not include H323 nor SIP protocols, so dial-peers can not be used.
UCCX uses JTAPI for call control for which you need either CallManager or CallManager Express.
HTH,
Chris
Bronze
Re: SRST and UCCCX
There is no way to do that since you can't have JTAPI integration with SRST. I would make sure you have the alias command under call-manager-fallback and have inbound numbers at least his an extension during a failover.
Re: SRST and UCCCX
You could run SRST as CME, but UCCX can be integrated with one or the other. So as an alternative you can implement second UCCX server and integrate it with CME (SRST).
Alternatively you can configure BACD on the router as a backup when site is in CME (SRST) mode.
Chris
Re: SRST and UCCCX
thanks for the responses, actually all I need to do is run a script on uccx that is for out of hours, we don't have any agents.
SO I am guessing I just need a dial peer
poinitng to the UCCX server?
Re: SRST and UCCCX
Re: SRST and UCCCX
HTH,
Chris
308
