Community Member
SRST - busy trigger equiv. / 2nd call doesn't get engaged
When running phones in SRST (7912/7940/ATA) I am finding that the second call to an extension does not get engaged, only the 3rd. Much the same as if you had the "BUSY TRIGGER" set to 2 rather than 1 in normal CM operation. Is there a way to prevent this so that all calls are given engaged tone, if the extension is already on a call, rather than allowing 1 caller to wait ?
1 ACCEPTED SOLUTION
Bronze
Re: SRST - busy trigger equiv. / 2nd call doesn't get engaged
If you have a dual-line phone configuration, use "huntstop channel" command to avoid hunting of call to the second line.
hth
mehmet
Bronze
hth
mehmet
Community Member
Thats seems to have worked. Thanks very much. I did also have to add "huntstop" to the "call-manager-fallback" config as the call was then matching an additional unwanted dialpeer rather than stopping on engaged.
356
