SRST call preservation question
Gateway is in SRST mode and there is an active call.
Gateway regained the connection with CUCM and gets registered to the CUCM.
What will happen to the call? Will that call be active or will it drop?
1 REPLY
Re: SRST call preservation question
It depends on the protocol being used by the gateway. With MGCP and PRI, there is no call preservation, but it can be done with H.323.
https://supportforums.cisco.com/docs/DOC-3048;jsessionid=24FB008DCA84C2B116777EAE72301720.node0
Hope this helps.
Brandon
256
