SRST CME called number redirect to Unity
HI,
Im trying to get the redirect called number working during SRST fallback.
Our network setup:
CUCM 7.1.5 and CUC 7.1.5 located at the HUB location, SPOKE site IP Phones regsiter to HUB CUCM/CUC via private network point to point. Both sites have voice gateway registers via H.323 back to HUB CUCM and dedicated ISDN lines with separate number range.
HUB -> CUCM/CUC -> H323 -> VG1 -> ISDN 6XXX
SPOKE -> IPPhones -> VG2 -> ISDN 3XXX
HUB VM Pilot Number: 68186222
SPOKE VM Pilot Number: 68093222
IP Phone Ext: 3015
Issues I need resolve during SRST fallback:
1. When I press the message button on my IP Phone ext 3015, I should hear "please enter your password followed by pound"
2. When outside calls my extension ext 3015, they should hear my voicemail greeting
voice translation-rule 1
rule 1 /^8830./ /68093000/
rule 2 /^88[5-9]./ /68093000/
rule 3 /^3\(...\)/ /68093\1/
voice translation-profile OutgoingCallerID1
translate calling 1
controller E1 0/0/0
pri-group timeslots 1-31
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-net5
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
isdn outgoing ie redirecting-number
no cdp enable
dial-peer voice 1 pots
translation-profile outgoing OutgoingCallerID1
destination-pattern 9T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
incoming called-number .
direct-inward-dial
port 0/0/0:15
telephony-service
srst mode auto-provision none
srst dn template 1
srst dn line-mode dual
max-ephones 265
max-dn 600
ip source-address 10.X.X.X port 2000
time-zone 41
date-format dd-mm-yy
dialplan-pattern 1 68093222 extension-length 10 extension-pattern 968186222#
voicemail 968186222#
max-conferences 8 gain -6
transfer-system full-consult
secondary-dialtone 9
Please help.
Everyone's tags (5)
1 ACCEPTED SOLUTION
In general, when you are using SRST and wish to integrate with VM then you need to pass the appropriate ISDN Information Elements (IE) to the carrier and that carrier needs to preserve the IE when presenting it to the far end voice gateway (HUB, in your case). In addition, the voicemail system needs to readily recognize the IE as associated with a mailbox user.
Let's work backwards. One of the common oversights is that the calling party (for direct calls) or the redirecting party (for forwarded calls) is not recognized as a subscriber on the VM system. This is an easy problem to address. Simply add an alternate extension to the voicemail user. So, if their internal extension is 3500 then add 68093500 as an alternate extension.
Now, lets look at the HUB gateway. In CUCM, configure the gateway and under the Inbound Calls Section enable the "Redirecting IE Number - Inbound" option.
Next, look at the carrier. You need to enable debug isdn q931 on both gateways. So, this means you will be simulating an outage to test. You can do this from the SPOKE site by either using ACL or sinking (nul) routes. Be sure to only interven in the call path to/from UCM and the phones/gateway at the SPOKE site (otherwise, you won't be able to telnet/ssh to the device and that is bad, real bad). Anyway, what you want to know is:
a. Is the SPOKE gateway sending: (for direct calls)
- called party: 68186222
- calling party: 68093500 (example)
(for redirect calls)
- calling party: variable
- redirecting party: 68093500 (example)
b. Is the HUB gateway receiving what the SPOKE is sending?  This is very key. Depending on the carrier and the market I have found that sometimes the redirecting party IE is stripped when it lands on the HUB. Though, the direct calls should work fine in all cases.
HTH.
Bill
http://ucguerrilla.com
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
HTH.
Bill
Re: SRST CME called number redirect to Unity
Thanks Bill.
Its helped alot. I found that the Telco expect our VG to send them 4 digits only instead of full 8 digits.
SPOKE
Calling Party Number i = 0x0180, '68093015'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '68186222'
HUB
Calling Party Number i = 0x0183, '68093000'
Called Party Number i = 0xC1, '68186222'
Issue 2 is now resolve aswell using "Redirecting IE Number - Inbound".
Thanks again.
I have removed the translation rule #3 outbound. Caller ID now works properly on both ends. Also using alternate number in Unity Connection at the HUB site.
This fixed issue 1.
958
