Community Member
SRST config
Hello All,
I am facing some issues during SRST, the active calls are successfully getting preserved however even after disconnecting the calls the voice channels are active ..... Can anyone advise what configs do I need to make it work ??
Many thanks
Anil Sharma.
1 REPLY
Community Member
Re: SRST config
Hi!
Could you please provide the current config? Also what kind of SRST are you running? CME-SRST or SRST?
217
