SRST configuration on Voice Gateway
I configured Fallback on my h 323 voice gateway and verified by denying a couple of phones communicating with CUCM through access-list and it works fine but calls are not going through both outgoing as well as incoming.
Trying to configure the SRST on the existing H323 Voice Gateway.
Please let me know whether my testing way is fine or it needs a different way to test my fallback service.
  • IP Telephony
Hi Harish.
Please post your VG configuration and specify where did you applied the access-list
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Re: SRST configuration on Voice Gateway
Hi Carlo,
Thanks for u r response, I had applied my access-list on the core switch to deny the communication b/w couple of phones and the CUCM cluster.
Here below is my config:
call-manager-fallback
secondary dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.x.x.x port 2000
max-ephones 250
max-dn 500.
Phones are registering to Voice gateway but calls are not going through.
only 2 phones are denied other phones as well as gateway is communicating to CUCM.
Any additional dial-peers required for SRST configuration on voice gateway to forward calls, I read in few blogs there is no need of additional dial-peers and it will use the existing dial-peers only to route the calls.
Re:SRST configuration on Voice Gateway
Show output of the "show voip dialpeer inout"
Sent from Cisco Technical Support Android App
I am not able to execute this command on the voice gateway...
Hi.
Omer meant debug voip dialpeer inout during an incoming or outgoing call from or to an ip phone in srst mode
Carlo
Thanks Mr. Carlo. I apologize as its my mistake.
I meant to say show the output of "debug voip dialpeer inout" & "debug voip ccapi intout"
I checked and as per the stats my outgoing calls are not matching with the existing dial-peers at all.
Hi Omar/Carlo - At wat time either of u guyz will be free to discuss this on live chat..
Hi.
I could be free at 21 GMT.
Let me know
Carlo
Here below is debug voice dail-peer for incomoing call from pstn.
an  7 11:39:20.206: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=0552017119, Called Number=0554, Voice-Interface=0x4955DEE0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
*Jan  7 11:39:20.206: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=22
   Calling Number=0552017119, Called Number=0554, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
   Result=NO_MATCH(-1) After All Match Rules Attempt
*Jan  7 11:39:20.206: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=0554, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=0554
   Result=Success(0) after DP_MATCH_DEST
*Jan  7 11:39:20.210: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=22
     2: Dial-peer Tag=5555
*Jan  7 11:39:20.218: //-1/2E81982B8811/DPM/dpMatchPeersCore:
*Jan  7 11:39:20.218: //-1/2E81982B8811/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=22
*Jan  7 11:39:20.218: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=0554, Called Number=0554, Peer Info Type=DIALPEER_INFO_SPEECH
*Jan  7 11:39:20.218: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=22
   Result=SUCCESS(0)
     1: Dial-peer Tag=22
*Jan  7 11:39:20.222: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=0554, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=5555
*Jan  7 11:39:20.222: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Jan  7 11:39:20.222: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=22
*Jan  7 11:39:20.222: //-1/2E81982B8811/DPM/dpMatchPeersCore:
*Jan  7 11:39:20.222: //-1/2E81982B8811/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=22
332
