Community Member
SRST Devices not Expected
CCM 4.2(3)
1760 12.1(3)T
SRST 3.1
In CallManager I have 24 phones in the SRST device pool. The other device pool is set to SRST-Disable.
When I simulate a CM failure (unplug the network cable) phones that are not part of the SRST DP are being registered and phones I wish to be enabled during failover are not.
Am I missing something somewhere?
Hall of Fame Super Red
Re: SRST Devices not Expected
Hi Ben,
No, you aren't missing anything here. Did you check that the Phones were reset after being assigned to the specific Device Pools. Or that if the changes were done at the Device Pool Level that you chose > Update>Reset Devices after making the changes?
Hope this helps!
Rob
Community Member
I'm sure I have, but I will definately try to reset them again and see what happens.
99
